Construction project closeout: How to prepare a complete handover package
10 min read
Oct 20, 2026
An aerial view of a team pouring concrete on a busy construction site.
What is construction project closeout?
The exact requirements depend on your contract and project, but a construction project closeout is generally the process of:
  • Completing outstanding work
  • Gathering required records
  • Meeting the conditions for formally closing a project
It includes physical and administrative activities, from resolving punch list items to submitting final documents and settling accounts.
The handover package itself is the collection of information you deliver to help the owner operate and maintain the completed building.
For you, success means knowing what’s been submitted, checked, and accepted—and what still needs attention. For the owner, it means being able to find the right information without calling your project manager every time a maintenance question comes up.
Construction project closeout checklist—what belongs in a handover?
Start with the contract, specifications, and owner’s requirements. Use the checklist below as a starting point, then confirm which documents and formats your project needs:
Document group
What to include where required
What to check
As-built drawings and models
Records of completed work, including required native files or exports
Correct revisions, clear identifiers, and completed changes
Operations and maintenance manuals
Operating instructions, maintenance schedules, equipment and parts details
Documents match installed equipment and are readable
Warranties and contacts
Warranty documents, dates, conditions, and service contacts
Correct equipment references and complete contact details
Certificates, tests, and signed records
Inspection certificates, test results, commissioning records, completion documents, and required approvals
Signatures, dates, supporting evidence, and any unresolved items
Training and handover records
Training materials, attendance records, demonstrations, and acknowledgments
Required sessions are complete and outstanding actions recorded
How to organize a complete construction handover package
A successful handover takes shape throughout the project. These five steps help you build it gradually, with Dropbox features providing a shared place for the files behind each step:
1. Agree on requirements and responsibilities early
Before requesting documents, confirm what a successful handover looks like to the owner. Ask:
  • Which documents and file formats are required?
  • How should files be named and grouped?
  • Who supplies each item, and who checks it?
  • When are submissions and reviews due?
  • How will the owner receive and access the finished package?
Then give each deliverable a named person responsible for supplying it and a reviewer.
On an office fit-out, for instance, the electrical subcontractor might supply panel schedules and test records, while the project engineer checks them against the agreed requirements. Recording that responsibility early gives you a clear person to contact when something needs correcting.
Keep the agreed requirements alongside your closeout tracker in the project folder in your cloud storage. You’ll have a reference point for follow-up requests as the work progresses.
2. Create a closeout tracker and clear folder structure
Your tracker is the packing list for the handover package. It tells you what belongs inside and whether each item is ready. A simple table in Dropbox Paper can often work well. Include:
  • Required document and relevant system or trade
  • Person responsible and due date
  • Reviewer
  • Status, such as requested, received, needs correction, or accepted
  • Link to the file
  • Outstanding comments
Use "received" and "accepted" as separate statuses. Remember that a submitted manual may still cover the wrong equipment model.
Build a simple folder structure alongside the tracker. Start with a "00 — Index and handover guide" folder that explains the package and helps recipients find what they need. Then try organizing the supporting documents like this:
Folder
Purpose
01 — As-built drawings
Store reviewed drawing deliverables
02 — Operations and maintenance
Group manuals by system or equipment
03 — Warranties and contacts
Keep warranty information easy to locate
04 — Certificates and testing
Collect required completion evidence
05 — Training and acknowledgments
Record training and handover activity
A screenshot of the Dropbox interface showing someone restoring one of their recently deleted files.
What causes closeout delays—and how can you prevent them?
Use your closeout reviews to spot missing documents, resolve outstanding issues, and keep the handover process moving while there’s still time to act:
Closeout problem
Practical action
Subcontractors leave before supplying records
Request documents as work finishes and keep a named contact for each requirement
Manuals don't identify the installed equipment
Check that each manual clearly identifies the correct product or model
Working drawings get mixed with handover records
Keep reviewed deliverables in a clearly labeled folder
Documents arrive without a designated reviewer
Assign a reviewer and deadline for each item in your tracker
The owner struggles to navigate the package
Agree on the structure early, provide an index, and test the handover together
How Dropbox helps keep closeout documents organized and accessible
You can use Dropbox to keep the files behind your closeout process together, from the first submission to the package you hand over. Consider the journey of an equipment warranty:
  1. Collect it: Request the warranty from a subcontractor and receive it in a chosen Dropbox folder.
  2. Check it: Confirm the equipment reference, required details, and relevant dates.
  3. Record its status: Update your tracker and link to the checked file.
  4. Organize it: Place the accepted warranty alongside the corresponding handover records.
  5. Share it: Give the intended recipient access through your agreed delivery method.
The benefit for your project manager is continuity—the file stays connected to the work of collecting, reviewing, and handing it over.
A good handover package stays useful long after your site team leaves. Keep a dated copy of the original package, index, and handover acknowledgment, so the information remains available.
Make your next construction handover easier to complete
Start with the owner’s requirements, assign responsibility, and collect checked records as the project progresses. By handover, you’ll have a package that’s easier to review—and easier for the owner to use.
By using Dropbox for construction, you can keep those records organized with the rest of your project and accessible to the people who need them. Give your next construction handover a clear home and choose a plan to get started.
Frequently asked questions
Construction closeout covers the wider process of finishing the project’s outstanding work and administrative requirements. Handover focuses on transferring the completed asset and the information the owner needs to use and maintain it. Your contract defines the specific requirements and milestones, so use those as your starting point.
Responsibility depends on the contract and project arrangements. The general contractor may coordinate collection, while subcontractors, suppliers, designers, and other contributors provide particular records. Assign a named person and reviewer to each deliverable so responsibility stays clear.
Agree on requirements early and collect documents as they become available throughout construction. Some records can only be finalized after testing or completion, so track their expected delivery dates. Building the package gradually gives you more time to resolve gaps.
Explore related resources
A group of people in a construction site meeting talk at a site office.
How to share construction site meeting minutes
October 17, 2026
Learn how to run construction site meetings and use Dropbox to store or share minutes effectively.
A drone shot of an expansive construction site from above.
How to share construction drone footage and collect feedback
October 15, 2026
Learn how to organize construction drone footage, share videos, and collect feedback.
A long-distance view of people working on a sprawling construction site.
Connect project files with construction software integrations
October 3, 2026
Learn how to pick construction software integrations and use Dropbox to organize and share project files.
