What is a hard drive? HDDs, SSDs and external storage explained
7 min read
11 Oct 2024
A hard drive is a piece of hardware used to store digital content and data on computers. These non-volatile storage devices employ magnetic disks to permanently store and retrieve data, forming the foundation of computers, laptops and other electronic devices.
Every computer has an internal hard drive but you can also get external hard drives that can be used to expand the storage of a computer.
Internal vs external hard drive: what’s the difference?
Traditionally, there are two primary categories for computer data storage devices: Hard Disk Drives (HDDs) and Solid State Drives (SSDs).
Internal hard drives
Internal hard drives reside within the device's case, seamlessly integrating with the system. They are integral to the device, providing the main storage for the operating system, applications and files.
External hard drives
External hard drives, on the other hand, are separate from the computer's internal system. They connect via USBs or other interfaces and provide additional storage space for your files, such as documents, photos, videos and music.
External hard drives are commonly used for:
  • Backing up data from your computer
  • Storing large files that exceed the internal hard drive’s capacity
  • Transferring files between computers
The difference between primary storage and secondary storage
Computers rely on two distinct methods for storing data: primary storage and secondary storage.
Primary storage, often referred to as main memory or RAM (Random Access Memory), is a volatile storage medium that temporarily holds data and instructions that are being processed by the central processing unit (CPU). Think of it as the “brain” of the computer. It holds data and instructions currently being used by the CPU. However, primary storage is expensive and has limited capacity, making it unsuitable for data storage in the long term.
In contrast, secondary storage is a non-volatile storage medium that retains data even when the power supply is cut off. It is used for long-term storage of data, such as operating systems, applications, user files and backups. Secondary storage devices are typically slower than primary storage but offer much larger storage capacities at lower costs. Examples of secondary storage devices include hard disk drives (HDDs), solid-state drives (SSDs), external hard drives and even somewhat outdated optical media such as DVDs and Blu-ray discs.
The key difference between primary and secondary storage lies in their volatility and speed. Primary storage is volatile and loses data when the power is turned off, while secondary storage is non-volatile and retains data even when powered off.
What is an HDD?
A hard disk drive (HDD) is a traditional type of storage device made up of magnetised disks called platters that spin at speeds between 5,400 and 15,000 RPM. Faster rotation speeds allow quicker data access.
Digital data is stored in binary code (ones and zeros). The read/write heads of an HDD magnetise portions of the platter to represent this data, with each bit being either 1 or 0. These heads can both read and write data by detecting or changing the magnetisation of the bits on a platter.
Whenever data is modified, such as saving or deleting a file, the read/write head adjusts the platter's magnetisation accordingly.
Because data is stored magnetically, HDDs are non-volatile, meaning they retain data even when the computer is turned off. Modern internal HDDs can hold up to 20 TB of data. Although less common as primary storage due to SSDs, HDDs remain reliable as an external storage drive option.
Person connecting an external hard drive to a laptop, illustrating hard drive usage for data storage and backup.
What does a hard drive do?
Simply put, a hard drive stores data. On a computer, this includes all of your photos, videos, music, documents and applications. Beyond that, the code for your computer’s operating system, frameworks and drivers are stored on hard drives too. The capacity of a hard drive is measured in megabytes (MB), gigabytes (GB) and terabytes (TB).
This is different from RAM (Random Access Memory), which is temporary computer storage that requires electricity to store data, making it volatile memory – it only stores data when the computer is turned on. RAM is not used for personal data, only computer data. Your computer needs memory to operate smoothly and allow you to jump from task to task or application to application without losing where you were. RAM is known as primary storage, while HDDs and SSDs fall under secondary storage.
A computer hard drive is a storage device required to hold on to your files and data for the long term. Whenever you save a file to your computer, you’re saving it to your computer’s hard drive. This essentially makes a hard drive a bit like a filing cabinet for your digital files.
External hard drive on a desk alongside file icons and a person working at a laptop, illustrating data storage options.
Types of hard drives: HDDs vs SSDs
HDDs and SSDs each have unique characteristics, performance capabilities and ideal use cases.
What are the advantages and disadvantages of HDDs?
Advantages of HDDs
  • Cost-effective: Generally cheaper per gigabyte compared to SSDs, making them economical for bulk storage
  • Storage capacity: Available in larger sizes, up to several terabytes (TB), which is beneficial for extensive data storage needs
  • Data longevity: Good for long-term storage of data that is not frequently accessed
Disadvantages of HDDs
  • Speed: Slower boot times, longer file transfer and load times
  • Power consumption: Uses more power, which can affect battery life in portable devices
  • Noise and heat: Generates more noise and heat during operation, which could impact system performance and durability
  • Fragility: Can be susceptible to damage if not properly protected
Common uses of HDDs
HDDs are best suited for bulk storage, such as media libraries and backups. They’re ideal for general computing tasks where budget is a consideration and high-speed performance is not critical. HDDs are best for:
  • Archival storage: Great for long-term data storage where access speed is not as important
  • Media libraries: Suitable for storing large media files like videos, music and photos
  • Backups: Cost-effective for regular backups and large data repositories
What are the advantages and disadvantages of SSDs?
Advantages of SSDs
  • Speed: Significantly faster data access, boot times, quicker file transfers and reduced application load times
  • Power efficiency: Uses less power, enhancing battery life in laptops.
  • Durability: More resistant to physical shocks and drops, making them safer for mobile computing
  • Silent operation: No moving parts result in silent operation
Disadvantages of SSDs
  • Cost: More expensive per gigabyte compared to HDDs
  • Storage capacity: Generally available in smaller capacities, with consumer models typically maxing out around 4 TB
  • Write endurance: Limited number of write cycles, which can be a concern with constant large data writes
Common uses of SSDs
SSDs are ideal for operating systems, applications and gaming. They are suitable for laptops and desktops where performance is critical. SSDs are best for:
  • System drives: Perfect for operating system and software installations for faster overall system performance
  • Laptops: Ideal for portable devices due to lower power consumption and enhanced durability—making them ideal for devices where battery life is important, such as laptops and mobile devices
  • Gaming: Provides better gaming performance with faster load times and responsiveness
  • Professional workstations: Beneficial for tasks requiring high-speed data access, such as video editing and 3D rendering
Choosing between HDDs and SSDs
The choice between an HDD and an SSD often comes down to the user's specific needs:
  • Budget and capacity: choose an HDD if you need large amounts of storage at a lower cost
  • Performance and reliability: opt for an SSD if you need high performance, speed and reliability
In many modern setups, users leverage both types—SSDs for the operating system and applications to benefit from quick access and HDDs for mass storage of data like videos, photos and documents. This hybrid approach maximises both performance and storage capacity.
Storing your data in the cloud is also an option
The arrival of cloud storage presented a solution to the limitations and risks of hard drives, offering a safer, more accessible data storage alternative. Saving a file on the cloud means storing it online, where it won’t take up any space on your device.
Dropbox cloud storage, for example, allows users to store, access and share their files from anywhere with an internet connection. This eliminates the need for physical storage devices and provides a reliable backup for important data.
Keep your files secure with Dropbox
Documents, photos, videos and more—Dropbox keeps all your files and folders safe in secure online cloud storage.
Still from a video explaining how much 1 terabyte of storage is, and how many files and docs can be saved with that limit.
Explore related resources
A person sitting at a desk connects their external hard drive to their laptop using a USB cable.
Guide to computer data storage: what is the best storage device?
With so many different types of computer storage devices available, choosing how to store your files can feel overwhelming. Explore our guide to work out which option best suits your needs.
A person looks at their monitor on a desktop computer in an office environment.
Can you recover overwritten files on your hard drive?
Overwriting a file by mistake can be a daunting experience. Use our guide to find out how to recover your overwritten files, and prevent it from happening again.
Photograph of a Dropbox user clearing space in their cloud storage.
How to clear your cloud storage in 5 simple steps
Clutter in your cloud storage can cause as much chaos as physical mess. Learn how to clear your iCloud, OneDrive or Dropbox storage with our guide.
