How to build and use project management workflows in eight easy steps
6 min read
13 Feb 2025
Two colleagues brainstorming on a whiteboard in an office.
How to build a successful project management workflow
Here are the steps you need to develop your workflow, with an example of each one in action:
1. Identify project objectives
Clearly define the goals and objectives of the project—what looks like a good result. Outline what you want to achieve with the project, the desired outcomes and how you’ll measure success.
By setting the project objectives early, everyone involved will have a clearer understanding of what needs to be done and how you can work towards a common goal.
When defining your goals, consider any specific requirements or constraints that may affect the project. It’s also important to establish key performance indicators (KPIs) that will measure the success of the project. These KPIs should be specific, measurable, achievable, relevant and time-bound (SMART) and should provide a clear indication of whether the project is on track to achieve its desired outcomes.
Example: Launching a new website to improve online presence and user experience.
2. Drill down tasks
Divide the project into smaller, manageable tasks. This makes it easier to assign responsibilities to team members, track progress and identify any potential roadblocks or challenges that may arise.
Breaking tasks down into smaller chunks can prevent the project from becoming overwhelming. You’ll find your day-to-day more structured, as you’ll be able to organise your time according to task priority.
Example: Breaking down a website launch into tasks such as design, content creation, development, testing and publishing.
Colleagues look at a sequence of sticky notes on a glass wall in a modern office.
A remote professional attends a video call from their home office.
Dropbox interface shows file management options, with a cursor selecting the share button on a folder.
Benefits of using a project management workflow
Here are a few reasons why Dropbox is the ideal tool for making sure project management workflows drive clean, productive business outcomes:
  • Efficiency gains: Project management tools help teams work more efficiently by streamlining communication, collaboration and file sharing
  • Accountability: Dropbox makes it easy to track task progress and hold team members accountable for their work
  • Communication made easy: Dropbox collaboration tools make it easy for team members to communicate with each other, both inside and outside the office
  • Speedy sprints and project timelines: The Dropbox Paper project plan template helps teams stay on track and meet deadlines by providing a clear overview of project progress
  • Pivot as needs change: Easy content collaboration makes it easy to adapt to changing project requirements by allowing teams to quickly and easily make changes to their workflows
Ramp up your project management
A well-structured project management workflow is essential for all types of projects and businesses of all sizes.
By following the steps outlined in this article, you can create a workflow that will help you improve efficiency, accountability, communication and productivity. The Dropbox suite of project management tools helps you put your workflow into action and exceed your project goals.
Explore the right tools and features to build effective project management workflows that deliver results.
Explore related resources
A team of people sit and stand around a desk, discussing how to set up a DMAIC process to support their project.
What is the DMAIC process and methodology?
Define, Measure, Analyse, Improve and Control. DMAIC is a data-driven approach to solving real problems at your company. But how exactly can it solve these problems?
Team sitting together discussing ideas and taking notes, representing collaboration and brainstorming sessions.
What are SMART goals?
Setting SMART goals is key to achieving success. Find out how to create specific, measurable, achievable, relevant and time-bound objectives with this essential guide.
Two people in an office look at a computer screen together, discussing edits to make to a file.
Effective document version control
Document version control helps you track changes, prevent data loss and ensure everyone in your team is working on the right version of a file.
